Since I will be doing away with the in/out board and using a 3PDT true bypass I presume I can ignore pins 6 and 7?
Yes, you can ignore pins 6 & 7.
I'll have to use the 5v regulator - what does it do on the main board?
Although I was able to trace the input/output board, the mainboard is too complex to trace,
so I can't tell you what the 5V is used for.
Here's the schematic of my new Input/Outputboard:
I also made a PCB for this circuit, but I can't find it right now.
I will post it as soon as I found it.
You could of course also choose to keep the original Input/Output board and remove the unused parts
and modify it to my new Input/Output board.
Please report back your progress because I still have to rehouse my RockyRoad and any idea is welcome.
André
