A/DA Flanger Clone
LaceSensor
Has thanked: 57 times
Been thanked: 277 times
Post by LaceSensor »
Selling an A/DA Flanger clone or will look at worthy trades / trades plus cash.
This is the daddy of all DIY flangers in my opinion. Sounds so great.
The enclosure size is (inches approx) 7 wide x 4.5 deep x 2.25 high
or in cm 18x11x5.5
Features:
- Moosapotamus PCB
- Panasonic MN3007 BBD chip
- ST and Ti chipset for the remainder
- +9v DC operation, LT1054 charge pump/7815 regulator internally for 15v operation
- Internal volume control potentiometer (can be set to unity or give a boost)
- Blinking bypass LED (never goes completely dim, useful for slow rates)
- Footswitchable Harmonics mode, with Bi-color indicator LED
- Shielded cable for the in/out
- Calibrated as per Moosapotamus instructions on Youtube (takes time to do properly, and the right tools)
- 100kb Threshold mod, for proper gating action, with 2n5457 FET
- Original artwork by me, using Toner transfer. Meant to ape the Lovetone vibe...
Due to the complexity and expense of this build, I feel £150 or the US equivalent is a good starting point for negotiations. Trade value a bit higher.
I like modulation and delay effects as a preference, not looking for overdrive/fuzz/boost
Let me know if interested. Only selling as I bought/built 2 of these.
Danyosound
Post by Danyosound »
Did someone buy it?
LaceSensor
Danyosound wrote:Did someone buy it?
Hi
This was traded
thanks
Ian
