OH! cool, so does this mean the blue sky isn't really diy friendly either?
Re: MR. Black - Eterna
Posted: 17 Nov 2012, 02:31
by Jack Deville
Good luck on that venture.
Posted: 17 Nov 2012, 04:39
by culturejam
Jack Deville wrote:Good luck on that venture.
Posted: 17 Nov 2012, 09:13
by roseblood11
a shimmer effect isn't worth a lot if it doesn't have a second output for the clean signal.
If you want anything else than a totally clean sound for the direct signal, you need two amps anyway...
Posted: 17 Nov 2012, 17:32
by Jack Deville
wrong
Posted: 17 Nov 2012, 19:15
by roseblood11
Sure, you can do some things with only one amp, but you can do most of them better with a stereo setup.
I see the shimmer effect as some kind of replacement for a keyboard player - it delivers an ambient sound and I can change sounds on my main signal without affecting the shimmer signal.
I don't really like pedals for this kind of sounds any more. I used a Verbzilla for a while, but a POD HD is much more flexible: You can use a dual mono setup for one part, a stereo setup for another and two completely different sounds for a third.
I really love building pedals, but I don't use them for modulation/delay/reverb anymore, at least not on stage.
