Walrus Audio - Mayflower [traced]
- mmolteratx
- Degoop Doctor
Would be willing to bet that it's a Tubescreamer with a Timmy bass control and a bipolar supply from a 1044 or 7660.
- Jack Deville
- sonicmojo
The 3.3K resistor off the bass control appears to be similar. There a couple of other 3.3K resistors around the Opamp too. I'm just guessing but I can't see anything else beyond that as far as the Timmy goes.mmolteratx wrote:Would be willing to bet that it's a Tubescreamer with a Timmy bass control and a bipolar supply from a 1044 or 7660.
- sonicmojo
I received my Mayflower today and played around with it for a little while....but couldn't resist checking out those chips. I might have set a degoop record. It took me less than 2 minutes to get the tiny bit of goop off the ICs. They are both RC4558P. Both the transistors are MPS A18.
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
that translucent shot is great!
any chance you can do the same from the other side? at similar angle (hard when hand held I know but orth a crack)?
- Jack Deville
- rocklander
- Contact:
onya.. thankssonicmojo wrote:Here's the other side in the light.
you sure? I mean.. you're the pro here but it looks like it's soldered to me...Jack Deville wrote:Riveting design.
- Jack Deville
- Blend
bump:
any schematic?
any schematic?
- mmolteratx
- Degoop Doctor
All information needed to draw a schematic is in this thread. Feel free to do so.ALDOUSCROSS wrote:bump:
any schematic?
- mmolteratx
- Degoop Doctor
Just did a quick trace, though I don't know why I bothered. It's a Timmy wrapped with Tubescreamer buffer stages, with a voltage follower buffered Vref. There's one resistor I can't find a place for without better pics, but appears to be part of the second Timmy gain stage. Will upload once I clean it up and figure out what the hell that resistor is there for. Slightly tweaked tone controls (series resistor in the Timmy treble control altered to 5k6, bass control caps are 10n and 1u) and a lower value gain pot. That's it.
- batteryacidtea
oh no, not you again!ALDOUSCROSS wrote:bump:
any schematic?
isn't this the guy that refused to share some of his "great secret schematics and layouts" some time ago?
- Jack Deville
- mmolteratx
- Degoop Doctor
