Page 2 of 3
Re: Walrus Audio Mayflower
Posted: 16 Jan 2013, 21:44
by mmolteratx
Just realized I accidentally placed the +9V tap at the +4.5V tap. Anyone reading it should realize the error pretty quickly.
Posted: 16 Jan 2013, 21:46
by mmolteratx
Here's the schem for anyone who wants to fix it. Not worth anymore effort though, IMO.
Posted: 17 Jan 2013, 19:54
by Motter
Pardon the newb question, and maybe this isn't the place to ask it, but can anyone explain the benefit of the buffered power supply? Is it less noisy?
Posted: 17 Jan 2013, 20:02
by Jack Deville
Here are some reasons to use a follower for a reference supply:
-Its stiff. Really stiff, without sacrificing current consumption due to low value resistors.
-Higher value resistors can be used, since the follower is doing the heavy lifting. That can mean lower current consumption (a balance between what the follower draws and what the simple divider draws).
-Higher value resistors mean lower value capacitors, which in this case have been negated. Don't ask why. I didn't design it.
-Its isolated from the rails. This means you can slam it with (relatively) huge signals and currents without causing the same disruptions in other sections of the circuit. There are limitations here, of course...
-A closer approximation to linear operation can be achieved as a result of the isolation. Think about it. You'll see it.
-Its confusing! Makes people stop and ask why, and anytime that happens, I'd say you've got a winner on your hands.
:applause:
Posted: 18 Jan 2013, 04:53
by mmolteratx
Low impedance out too, so less susceptible to external noise interference, and less voltage drop under operation. I use them on occasion when I need a bias supply for several devices.
Posted: 04 Feb 2014, 01:51
by newly
mmolteratx wrote:Just realized I accidentally placed the +9V tap at the +4.5V tap. Anyone reading it should realize the error pretty quickly.
So all "+9V" should connected to "V+" instead right? VB remain as 4.5V.
Posted: 04 Feb 2014, 15:42
by grrrunge
Jack Deville wrote:Here are some reasons to use a follower for a reference supply:
:applause:
Thanks for the informative reply! :) Just out of curiosity, would the results be the same with a BJT or JFET buffer?
Posted: 10 Feb 2014, 05:59
by mmolteratx
Yes.
Re: Walrus Audio Mayflower  [traced]
Posted: 15 Aug 2014, 04:58
by mmolteratx
After being hit up by IVIark to see if I had done any more work on this, I cleaned up the schem and did a quick retrace. The original doesn't really do anything with the unused op amp half, but I included it tied to Vr, which is better practice. Result is attached.
Posted: 15 Aug 2014, 20:09
by IvIark
Here's the vero
and one with a standard voltage divider for vref, doing away with the second opamp. I'm not convinced it will make a difference in something like this, and so would prefer to save the space.
Re: Walrus Audio - Mayflower
Posted: 24 Feb 2016, 17:37
by MilesXC
Only got 1uf electros lying around. Can anyone help tell me which way round they should go until I get replacements?
Posted: 24 Feb 2016, 18:54
by 287m
hey Miles
You can make a quick and dirty 1u nonpolar wannabe capacitor by tying together the negatives of 2 1u electro
then solder positive leg to board
Posted: 24 Feb 2016, 19:32
by MilesXC
So I just have two together with the positives on the board?
That's great, thank you : )
Posted: 24 Feb 2016, 20:25
by 287m
yes :thumbsup
Posted: 25 Feb 2016, 07:21
by Blitz Krieg
^^^^ 2 uf?
Posted: 25 Feb 2016, 09:36
by MilesXC
I think it would only be 2uf if they were wired in parallel : )
Posted: 25 Feb 2016, 13:20
by grrrunge
287m wrote:hey Miles
No! Capacitances in series adds up like resistances do in parallel. 2*1µF in series would effectively give you 0.5µF.
To get 1µF you'll need two 2µF caps in series ;)
Posted: 25 Feb 2016, 14:15
by mictester
C7 into the volume pot has a -3dB point of 16Hz! You could easily use 470n for the 1u caps in the audio path with no significant change in the (audible) frequency response. You could put two 470n caps in parallel for the "Bass" cap....
Posted: 25 Feb 2016, 18:23
by 287m
Blitz Krieg wrote:^^^^ 2 uf?
no, two 1 uF polarized (+-) wired in series like +--+ , still 1uF
normally, you right.
normal elco actually conduct in the reverse direction, two 1uF polarized act like they each have a diode in parallel with them that conducts when the voltage is backwards for that one cap.
Posted: 26 Feb 2016, 05:58
by grrrunge
Where did you learn that? I have never seen any diodes in the equivalent diagram for electrolytics. Only capacitance, inductance and resistances.
As far as i know, the only reason electrolytics are polarised devices, is because improper DC-bias will break down the dielectric layer.
