boidek wrote:this is the incomplete sketch:
[butchered=image]taken from beavis[/image]
can someone complete it?
boidek wrote:No one???
The way you've drawn it, your footswitch connects the circuit board input to either the output, or through an LED and a 2k2 resistor to +9v. Can I politely suggest you study and get to grips with plain old 3PDT true bypass wiring, then have a look at Cornish's.
boidek wrote:
1. Any Idea why stereo and not the regular mono?
Cheap, isolated stereo plastic jacks bought in bulk?
boidek wrote:
2. why grounding the input/output?
boidek wrote:
3. Also noticed he uses 2 resistors and a ceramic cap on the output. a. any idea why?
Which pedals? Got a picture, link, anything?
This is on the first page of the G2 thread, I see two resistors on one jack, can't read the values on my phone. One appears to link the two input lugs of the switching jack together, the other is probably an output pull-down resistor[/url]
As for a cap:
soulsonic wrote:culturejam wrote:mictester wrote:It's a fairly common way (especially in the RF engineering world) to ground a panel. It gives DC isolation, but the screening properties of the case are preserved.
Wouldn't that mean that the cap would always been in the signal path, regardless of whether or not the G2 was bypassed?
Yes, but if you look at the schematic, you see that the sleeve connection of the output jack still connects directly to the chassis ground via the ground path of the circuit board that it's connected to. The output jack connects to the chassis via the cap, make sure the chassis screens the signal sufficiently, but the cap is used to make sure there are no DC ground loops caused by any difference in potential which may exist between the input and output jack grounds.
At least, I think that's what is going on!
...is on page 4 of the thread.
boidek wrote:
4. Can anyone post an off-board drawing of his pedals?
Which pedals? The G2 in the photo above has an input board with the buffer: The input goes direct to the daughter board, then on to the switch: The switch sends it on to the main circuit board (a buffered Big Muff ) or bypasses it to the output, wired in the normal way i presume.
[edit]Actually, just look at the schematic, it's all there.... 50k resistor to ground on the output and a 0 ohm resistor across the output tip lugs - I'm never going to get those ten minutes back...[/edit]
