Tube Cake 3W
- Ice-9
I'm busy checking the schematic against the PCB I dont see R14 on the PCB. It looks like it has totally been jumpered. The rest of the PCB checks out fine with the PCB. (Ihave just assumed the pin outs for transistors are the correct as I did not check datasheets for pinouts).
If all is ok i share PCB layout. The most important thing is to check the smd elements outputs before wiring, if anyone find some mistakes shere your opinions with me i will redesign the pcb if there will be mistakes with transistors.
TC3.pdf- (95.05 KiB) Downloaded 109 times
- Ice-9
No I have not checked the pin outs match the data sheets, ~I just checked the PCB matched the Schematic. I will get the datasheets later and check they correspond, then I will post back. Is there any reason you have left out R14
- Ice-9
Me too, I didn't notice you fixed this in the next layoutarmkon wrote:I was sleepyit was 2am when i have this idea to make PCB haha That the reason
I have just checked the datasheet for the TIP31-32C and they are different from your layour, ie the middle pin is not base it is the collector so double check these.
- Ice-9
http://www.fairchildsemi.com/ds/TI/TIP31C.pdfIce-9 wrote:Me too, I didn't notice you fixed this in the next layoutarmkon wrote:I was sleepyit was 2am when i have this idea to make PCB haha That the reason
I have just checked the datasheet for the TIP31-32C and they are different from your layout, ie the middle pin is not base it is the collector so double check these.
also thebcp56 has a different pin out
http://www.onsemi.com/pub_link/Collateral/BCP56T1-D.PDF
- okgb
maybe only vaguely but the circuit looks a little similar to the 2520 style opamps used in
A.P.I. type mic preamps , usually have a hefty output section to drive transformers
not sure if that'll help you in the design department
Aleksei wrote:This circuit board was made for this project http://guitar-gear.ru/forum/topic/3081- ... %BC%D0%B8/
There is an example of sound in the beginning of the topic.
- J0K3RX
- Degoop Doctor
Aleksei wrote:Aleksei wrote:This circuit board was made for this project http://guitar-gear.ru/forum/topic/3081- ... %BC%D0%B8/
Holy Shit!!!
- J0K3RX
- Degoop Doctor
J0K3RX wrote:Aleksei wrote:Aleksei wrote:This circuit board was made for this project http://guitar-gear.ru/forum/topic/3081- ... %BC%D0%B8/
Holy Shit!!!That sounds incredible man!! Great Work!!!
J0K3RX You give us schematics and layout for two different things...
TC3 is different device then what you put in here as layout and images... It's not Tube Cake it's different PA 10W on signal without clipping
- J0K3RX
- Degoop Doctor
Yeah, I realized that after I posted..armkon wrote:J0K3RX You give us schematics and layout for two different things...
wow you guys very rock's
i'm planing to build this tube cake with non SMD component,
but can i change j177 jfet's with bipolar transistor like bc 557 ?
and what is the replacement for the bcp 56 ? maybe bd139 can do it?
any recomendation?
sorry for the silly question
any recomendation?
