Behringer fs112v footswitch details required please.
Locked
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
I recently scored a Behringer LX1-B Bass V-Amp cheap on fleabay but it doesn't have the 2 button FS112v (or FS112V-2) footswitch with it.
The footswitch has an attached cable with a 1/4" stereo jack (TSR).
Does anyone know how the footwsitch is wired internally (schematic) or have one they can post gutshots please.
I know it has a couple of momentary action switches and not much else so it is going to be pretty simple.
Thanks.
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
I have one. Momentary microswitches indeed, with parallel debouncing caps IIRC. The DOWN button shorts tip to sleeve, the UP shorts ring to sleeve.
deltafred
Post by deltafred »
FiveseveN wrote:I have one. Momentary microswitches indeed, with parallel debouncing caps IIRC. The DOWN button shorts tip to sleeve, the UP shorts ring to sleeve.
Thanks very much, just what I needed. :hug:
Locked
