Have fun with it. I hope this link will work.
https://img407.imageshack.us/my.php?ima ... prebk4.gif
[/URL]JHS
[/URL]Yes I have seen that, but what happens, when the switch - which sudddenly occurs - has contact problems ?There is a common 1M pulldown at the input.
Hmmm....we have a plate resistor of 100k and a cathode resistor of 1k5. The lower (-3db) corner frequency with a 22µF bypass cap is 9,3 Hz, with a 250µ approx. 0,9 Hz...... the lowest frequency of a guitar approx 80 Hz, the lowest audible frequency 20 Hz...... how does the 250µ produce, effect or contribute to a "deeper lush bass" than a 22µF250uF is std. at this stage, for that deep lush bass but it can be reduced 'til 4,7uF to tighten the lows, but I prefer to throttle down the Bass-pot (around 0-2) to tighten the bass.
ConfirmedJHS wrote:22uF is enough when you calculate this stage but you can hear a difference in sound with a 250uF.
JHS
