2n2222A vs P2n2222A
Hi all. Silly question, probably deserves a silly answer. Are these two essentially the same? Cheers.
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
http://en.m.wikipedia.org/wiki/2N2222
P-designation has a lower collector current, not sure that would make a difference in a 9-volt stompbox application.
