BYOC Comp Threshold Control + Vbias question
Just getting my feet wet here.
I'm looking into controlling compression threshold in a Dynacomp based pedal. Attached is the BYOC Comp schematic with some markings. I'm thinking that threshold could be increased by connecting a pot to ground at those locations. My train of thought: cranking the pot lowers its resistance -> overall sidechain signal level is dropped -> more signal is needed to get the same amount of compression. Voila! Threshold control! Can someone more experienced than I tell me why this would or wouldn't work?
Separate topic: the Dynacomp derived pedals I've looked at have a 4.5V bias at the 3080 input stage, sandwiched between 3.3V bias at Q1's base and the 3080's output. What's the deal there? I changed my pedal to universal 4.5V bias and it didn't seem to sound any different, so it seems to me like an unnecessary complication.
Well, the "sustain" pot is already a threshold control. (and btw the "attack" pot is actually a release control - see the emma transmogrifier for proper attack/release controls)
You may want to investigate how to add a "ratio" control to this circuit, this is a mod I've never seen.
Well, the Emma is a Dynacomp with mods.
https://www.freestompboxes.org/viewtopic ... hilit=emma
And the Dynacomp is actually a limiter, not a compressor. The pot changes threshold. There's a plot of the limiting curve of a Dynacomp with the pot on max and min on the trhead about merlin's "engineers thumb", where you can clearly see this.
https://www.freestompboxes.org/viewtopic ... mb#p207519
So, in a Dynacomp-based circuit, Sustain and Threshold are the same thing, and my suggested mod (if it even works) will sound more-or-less the same as what's already being done with the Sustain pot?
Oh man, I just realized how stupid my mod is (beyond the fact that sustain = threshold). Because Dynacomp-likes get their output from Q2's emitter, those pots won't just attenuate the sidechain level - they'll attenuate the output.
Maybe if I added a transistor buffer stage directly in front of Q2, and tapped the output audio from there, then I could mess with the sidechain levels...?
