Low Profile Electrolytics
gtrgeo
my favorite amplifier: My Blues Deluxe
Completed builds: Anderton TSF, ROG 3LD, booster, Bluesbreaker, Guv'nor, Cherry Buster (buffer-boost)
Post by gtrgeo »
Where is the best place to purchase low profile electrolytic caps? I have checked Small Bear, Tayda, Mammoth, and Pedal Parts Plus with little luck. Tayda had a couple values and the others don't indicate in the parts description.
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
I get 'em off ebay
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
aionios
Been thanked: 369 times
Post by aionios »
Mouser. Shipping isn't cheap for small orders, so you may want to wait until you need a bunch of resistors or box film caps or something, but they have a great selection of low profile electrolytics that I use all the time. Once you get inside the Electrolytics category, one of the search tools will let you search by dimensions - find the shortest one and then go for smallest diameter after that. Usually the brand will be NIchicon, sometimes Panasonic.
gtrgeo
Post by gtrgeo »
Thanks for the suggestions. It is looking like Mouser may be best solution for one stop shopping.
roseblood11, your suggestion for uk-electronic made me think I should search subminiature instead of low-profile. This lead to a surprise. Parts Express has a selection of sub-mini caps at reasonable prices. Just need to be careful as the voltage ratings run 10-450v.
I have a surplus place nearby work that I will try first but will probably just need to work up an order for the pedals on my to-do list and hit Mouser.
Has anyone tried DigiKey? Their prices seem reasonable but I had a tough time navigating their part selection filter.
Thanks,
George
