EH - Clone Theory ( versions )  [schematic]
Professor SourTone
Been thanked: 58 times
Post by Professor SourTone »
This was brought up on another forum, and in researching I found this page. I have two old Clone Theories, an earlier one with red graphics and an "edge" switch, and a later one with chorus/vib-vib/flange switch instead. I like the red one better, with the edge "on" always.
This site says they have different chips. It says the earlier version is based on the SAD1024 chip, and the later one on the MN3007. Is this so? I can dig them out and have a look, of course.
http://electroconducive.googlepages.com/ehxclonetheory
EHCloneTheory.pdf
EHX Clone Theory project files
(165.81 KiB) Downloaded 381 times
Been thanked: 124 times
There were two versions, the early one from 1977 with SAD1024A and the 1980 version with MN3007.
They are similar but from a schematic viewpoint they are totally different - not only the BBD has been replaced, the complete circuit was reworked.
guts are always welcome, especially since I don´t trust the EH-1317 (SAD1024A) factory schematic.
Professor SourTone
WilCo
andregarcia57
Has thanked: 60 times
Been thanked: 104 times
Post by andregarcia57 »
hum... great!
Professor SourTone
Sorry, forgot - will attempt this w/e
nelson
Post by nelson »
Professor SourTone wrote:Sorry, forgot - will attempt this w/e
I'd love to see them too.
Professor SourTone
Vib Flange version
Edge version
Professor SourTone
Oddly enough the edge version has the MN3007 and the board layout looks similar to my uneducated eye.
Thats not very astonishing. The edge version is from the end of 1979 and the other is from mid 1980.
Thanks for the pictures. Here is a different version, maybe the SAD-version.
Professor SourTone
That's interesting - so there appear to be 3 versions
SAD with Edge
EH 3000 MN3007 with Edge
EH 3000 MN3007 with VibFlange
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
thanks for great pictures :applause:
theehman
Has thanked: 97 times
Been thanked: 102 times
Post by theehman »
Professor SourTone wrote:That's interesting - so there appear to be 3 versions
SAD with Edge
Are the slide switches in your units wired the same? Maybe you have a transitional unit?
Ron Neely II
fx schematics and repairs
Professor SourTone
They can't be wired the same because the functionality is different. There do seem to be a couple of extra caps on the trace side of one of the circuit boards. Unfortunately once again I do not have the units with me...
theehman
Post by theehman »
Professor SourTone wrote:They can't be wired the same because the functionality is different. There do seem to be a couple of extra caps on the trace side of one of the circuit boards. Unfortunately once again I do not have the units with me...
I think those caps are on the back of the board due to space reasons.
Ron Neely II
V1nce69
my favorite amplifier: Ampeg
Completed builds: Veroboards builds:
Throbak Overdrive Boost
Wampler Ecstasy
Creepy Fingers Doomidrive
Black Arts Quantum Mystic
Roger Mayer Voodoo Bass
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Fulltone 69 (GGG kit)
Russian Big Muff (Musikding kit)
EHX Bassballs (home etched using Topopiccione layout)
BJFE BBOD (home etched, thx FSB)
Triangle Muff (Guitar PCB board)
Deluxe Bass Fuzz (home etched,gausmarkov.net layout)
Clone Theory Chorus (Celeste pcb from lectric-fx)
Cornish G2 (home etch, layout thx FSB)
Shin-Ei FY-2 Ge version (home etched, own layout)
Klon (Aion Refractor pcb)
Mutron Phasor II (home etched, layout thx JohnK)
Sunny-T (pcb by guitar pcb)
Rocket Overdrive (pcb by Pepers' pedals)
Sonomatic Deluxe Tape Delay (pcb by Skidmark)
Black Arts Quantum Mystic (adapted storyboardist layout)
Has thanked: 36 times
Been thanked: 110 times
Post by V1nce69 »
I own a vintage Clone Theory that is an EDGE SAD version.
Here are some pictures of its guts:
outside view
outside view
inside view
inside view
the board, rear side
the board, front side
original EH1317 schematic
May be these can be of some interest to all of you. :D
Vince
Scruffie
Has thanked: 28 times
Been thanked: 170 times
Post by Scruffie »
Having traced through those MN3007 units above (they are both wired the same for the edge switch so I don't know why they sound different but the edge one is just a transitional model) I think i've discovered that both Tom Boy and subsequently Nelsons schematics are incorrect, here's what i've got so far;
This applies to the Nelson schematic;
No - C19
No - C20
No - C7
C22 - 560pF
C17 - Possibly 220nF?
R33 & 34 - 220k
5k Cancel Trim (No R10 & 11)
C8 - 100nF
R21, 22 & C14 wrong, R22 (160k, maybe 150k on the other unit) and R21 (1k?) with switch pole coming from the center, R21 goes through 100nF to ground.
Output, Pin 7 through 1k? (switch pole connects here) with ?? Cap to ground in to ?? Output cap with 100k pull down.
If anyone has a unit that can help confirming all the cap values and those 3 questionable resistors that'd be a help in getting a correct schematic.
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Email me Scruff, I got a SAD1024 unit.
Image Ken
Scruffie
Post by Scruffie »
As far as I can tell, this is now 100% correct for the MN3007 version except for the values of C5 & 6 which I have left as 680pF for now as the original has a cap labelled 412 and I cannot confirm what the actual value is, both 412pF and 4,1nF seem like very odd values.
Vib Flange Switch is shown incorrectly, 2nd half should be in N.C position and the input opamp should be U1A - RC4558.
Thanks to pinkjimiphoton for confirming some values from his original units.
pinkjimiphoton
my favorite amplifier: my own, a redesigned princeton
Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks
Has thanked: 358 times
Been thanked: 477 times
Post by pinkjimiphoton »
alright, ya got it done!! sweet!! i wanna build one now, cuz the other one is similar (the toppopiccione site one) but i think it's a modded small clone, not a clone theory.
the actual mn3007 clone theory is THE one to have. the sad1024 version with the "edge" switch is pretty much a "feature" that lets the full frequency of that hiss come thru... ;)
Slava Ukraini!
Scruffie
Post by Scruffie »
pinkjimiphoton wrote:alright, ya got it done!! sweet!! i wanna build one now, cuz the other one is similar (the toppopiccione site one) but i think it's a modded small clone, not a clone theory.
Nah the toppopiccione one is a clone theory, only the filtering & feedback is a bit wrong, there's some unnecessary parts and a few wrong values.
But yup, got it all confirmed and eventually got hold a copy of the factory schematic, my redraw is correct.
Keep an eye on the madbean forum in the next few days too :wink:
