Footswitch grounding
McHuge
Post by McHuge »
Does the casing of the footswitch have to be ground? I have finished a treble booster for my board and that is housed in an aliminum box but the pot, switch and 3pdt footswitch are housed on a non conductive surface. Before I Installed it, the booster worked like a charm but now I have installed it, every metalic part of the board makes a sound when I touch it and there is now a ground loop buzz. I've used the audio beavis instructions on wiring a stompbox and I have double checked it. The effect works but the buzzing is doing my nut it!! I just wondered if I grounded the casing of the footswitch it may solve the problem.
Hope this makes sense!! :oops:
Has thanked: 218 times
Been thanked: 857 times
Seems there's no circuit ground connection to the case.
McHuge
Post by McHuge »
You mean from the switch to the aluminium case?
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
Dirk is wondering if your metal case is actually grounded: Buzzing when you touch it suggests it is not. The metal case would normally be grounded by the sleeves of the input+output sockets IF you're using metal (uninsulated) jack sockets. If you're using plastic insulated sockets (i.e. where the cable sleeve lug is not electrically connected to the part of the socket that touches the case) you'll need to make a separate ground connection to the case to provide shielding. You should not need to ground the stompswitch - If the case is grounded, the metal parts of the FS that touch it will also be grounded. While you're at it, check that ALL points that should be connected to ground, i.e. power negative, circuit ground, input/output sleeves, volume pot lug 1 etc, are actually connected to the same common ground.
McHuge
Post by McHuge »
All grounds are connected to the ground on the output lug of the socket. The case itself is a AC mains socket chassis (I'm skint and I heard they do the job!!) so it is conductive plus it has an ground point which again is connected to the out put lug. The footswitch then goes of to an another mains chassis box but with a hard wood lid that houses footswitches for the booster, amp channel selection and the reverb (following this?? :D ). One of the lugs on the footswitch goes to ground so I figured it would be earthed.
Another theory I have discovered is it could be my power supply. Its a cheap ebay daisy chain job. Would a proper iscolated power supply be the solution??
Again, I hope you get this :oops:
