On another note, is there as big a difference between germanium and silicon diodes as there is with germanium and silicon transistors in Fuzz Faces in overall sound?
Is This Diode Germanium or Silicon?
I'm onto my 2nd and 3rd DIY projects after completing my PNP Germanium Fuzz Face - an NPN Silicon FF and an MXR Distortion +. I've already bought most of the parts for the D+ from this Tonepad schematic (http://tonepad.com/getFile.asp?id=6). I am having a hard time finding out whether the 1N914 Diodes I bought (http://www.pedalpartsplus.com/mm5/merch ... y_Code=DIO) are silicon or germanium. Google searches bring up results that list them as one or the other
. Which one is it?
- my favorite amplifier: 1986 Gallien-Krueger 400RB
- Completed builds: BYOC 2-knob compressor
Klon Buffer
Devi Ever Ruby, OK, Hyperion
EP-boost->Modded SD1
Meathead
Hunny Bunny
Roger Mayer Voodoo Bass (excellent)
Zendrive
Big Muffs (Russian, P19, Jordan Creator, Jumbo Tonebender)
Lots of other miscellaneous pedals that aren't worth mentionin - Location: MA, US
- Has thanked: 7 times
- Been thanked: 6 times
- Contact:
1N914s are absolutely silicon. For all intents and purposes, the 1N914 is identical to the 1N4148, which is pretty much the most common small signal diode on the market today.
There is also a pretty big difference between germanium and silicon diodes, as germanium diodes have a lower forward voltage than most silicons. Silicon diodes will give you a louder, more compressed sound, while conversely, germaniums will give you a softer, more open sound. I strongly prefer silicon diodes in a D+, but it's up to you to experiment!
Thank you! That's what I thoughttriplesevener wrote:1N914s are absolutely silicon. For all intents and purposes, the 1N914 is identical to the 1N4148, which is pretty much the most common small signal diode on the market today.
