Tweed amp caps question?
- KHELSTROM
I'm making a replica of a tweed deluxe and have access to many of these cornell dubilier caps. Does anyone know the composition of these caps and are they the same as or similar to the old Astron caps found in the original tweeds? I also have access to paper and oil caps but my research has concluded that these Astron caps used in the mid to late 50s were not paper and oil composition.
KHELSTROM wrote:I'm making a replica of a tweed deluxe and have access to many of these cornell dubilier caps. Does anyone know the composition of these caps and are they the same as or similar to the old Astron caps found in the original tweeds? I also have access to paper and oil caps but my research has concluded that these Astron caps used in the mid to late 50s were not paper and oil composition.
You don't plan on using old caps for your build do you?
- jrc4558
IMHO, film caps dont dry out like ceramics of eletrolytics, and, if stored properly, can be used even in old age.Spewbag wrote: You don't plan on using old caps for your build do you?
