millenium 2 bypass plus
codycale
Post by codycale »
i am sure there is a very simple answer to this, but i want to build the millenium 2 bypass plus circuit so i can send the fx input to ground when bypassed and have an led, but i am not sure where to connect the signal shunt line. this is the shcematic from rg keen that i am using http://www.geofex.com/article_folders/m ... l2plus.htm can anyone tell me where exactly the signal shunt connects to. does it connect to the same lug on the switch that goes to the fx input? if so, does that not load down the guitar signal?
Groovenut
Has thanked: 60 times
Been thanked: 100 times
Post by Groovenut »
codycale wrote:i am sure there is a very simple answer to this, but i want to build the millenium 2 bypass plus circuit so i can send the fx input to ground when bypassed and have an led, but i am not sure where to connect the signal shunt line. this is the shcematic from rg keen that i am using http://www.geofex.com/article_folders/m ... l2plus.htm can anyone tell me where exactly the signal shunt connects to. does it connect to the same lug on the switch that goes to the fx input? if so, does that not load down the guitar signal?
I think this makes it a little easier to see. This is not the millennium 2 plus but it serves for illustration. You can see that if you attach the signal shunt line of the MB2+ to the terminal on the switch where the effect input is connected, that when the effect is active the signal shunt line becomes a high impedance path essentially isolating the effect input from ground. When the effect is bypassed the signal shunt line becomes a low impedance to ground, essentially grounding the input of the effect, while the footswitch routes the signal around the effect to the output.
Millennium Bypass 2 +
If I am interpreting RGs layout right this is how I would wire the switch
MB2+ DPDT Switch wiring
MB2+ DPDT Wiring.jpg (8.81 KiB) Viewed 907 times
codycale
Post by codycale »
thank you for your response. i did assume that was how it worked, but i guess sometimes it helps to have some things explained two different ways.
