PCB planes
benobo
Has thanked: 35 times
Been thanked: 11 times
Post by benobo »
Hello Gentlemen,
I have created a PCB layout on Eagle, and used the bottom side for the Ground plane and the top side for the Vbias (+4.5V).
My question is the following : Is it usual and ok to do it this way ? or should I trace the Vbias connections ?
Thanks for your time.
Benobo
phatt
Been thanked: 338 times
Post by phatt »
My guess,,Not normally done. Maybe Post a pic of layout,, I'd love to know where the signal wires go?
Assuming it's a home build pedal gizmo then it pays to not make things complicated.
Very fine traces and tiny pads (usually default for PCB software) are a nightmare to hand drill and if you also have pads and tracks very close together then it can lead to a nightmare to fault find.
Single sided boards with little or no ground infills are going to be a lot easier to track down issues later.
Phil.
