PCB tinning
Posted: 15 Jan 2013, 19:39
Hello everyone,
I have come across a method used to tin pcb copper tracks that is based on a product named ROSOL 3, by Rothenberger. It is a material used by plumbers and consists of copper and tin, as far as I am aware of.
So you apply it on the whole pcb surface, then use a thermal gun (or oven) at 200-250 degries Celcius, and as soon it is dry, you wipe the excessive material using a toοthbrush in a bowl filled with water.
Seems to work in a video I have watched.
Does anyone in here know about such a method, and whether it is efficient? Thanks in advance!
