RM 9090a wah
- ppluis0
Hi SFTFN,
Can you tell us what model of transistors are soldered in this board ?
FWIW, the inductor is made from an EPCOS (formerly Siemens) ferrite core: the material compound is N48 that is well suited to work at low frequencies, and the other number stamped "630" indicates a coefficient since this core has grinded an air gap internally.
To obtain the usual value of inductance needed in a wah pedal (500 mH) we must crank about 891 turns of enameled wire in this particular size of core.
