Castledine Electronics - The Wizard  [traced]
Manfred
Has thanked: 1090 times
Been thanked: 698 times
Post by Manfred »
Schematic and layouts, the capacitor values should be correct now.
WizSprintLayoutFile.zip
(18.91 KiB) Downloaded 20 times
I cerated a Vero-layout, but it is not applied yet and not verfied until now.
The lot of wire jumper results from the trial to keep the layout small.
WizLochMasterFile.zip
(147.33 KiB) Downloaded 20 times
WizVeroComponetSide.pdf
(267.32 KiB) Downloaded 21 times
WizVeroBothSides.pdf
(328.06 KiB) Downloaded 24 times
The solder side is folded downwards shown.
WizVeroSolderSide.pdf
(65.59 KiB) Downloaded 22 times
WizVeroSolderSideOriginalSize.pdf
(66.21 KiB) Downloaded 23 times
Manfred
Post by Manfred »
A re-examination gave some other resistor values as follows:
R4 old 22k -> new 10k
R5 old 4k7 -> new 3k9
R18 old 22k -> new 10k
R19 old 22k -> new 10k
R20 = 22R added.
WizSprintLayout6_FileCorrected.zip
(20.23 KiB) Downloaded 30 times
WizPCBSolderSide.pdf
(4.76 KiB) Downloaded 30 times
WizPCBSolderSideMirrored.pdf
(4.77 KiB) Downloaded 25 times
WizVeroBothSidesCorrected.pdf
(331.29 KiB) Downloaded 27 times
WizVeroSolderSideCorrected.pdf
(65.53 KiB) Downloaded 29 times
WizVeroSolderSideCorrectedOriginalSize.pdf
(66.17 KiB) Downloaded 27 times
Intripped
Has thanked: 688 times
Been thanked: 215 times
Post by Intripped »
hey! :D
..may i ask where did you take these new values from?
have you got the real pedal on your bench?
i can see that the old values of the resistors are coherent with the pics in the previous page, so ...are there 2 versions of this circuit?
would be interesting to determine which is the most recent
thanks again for your work!
Manfred
Post by Manfred »
Intripped wrote:hey! :D
No, I have not got the pedal on the bench, I got the information form another source.
I do not know which is the most recent, I guess the second one.
But anyway-the second one is verified.
Blues1911
Been thanked: 12 times
Post by Blues1911 »
Manfred wrote: No, I have not got the pedal on the bench, I got the information form another source.
Manfred, please notice that C2 value is reported right on the PCB (47uf) but not on the schematic, where is still wrongly noted as 100uf.
Manfred
Post by Manfred »
Hi Blues 1911,
thanks for the hint.
Here the corrected Schematic:
