power isnt something you want to f*** with
Bench Power
- commathe
Personally, I just use an adjustable DC wall wart. Then I have a vero-board supply filter with my in and out jacks built on to it (that way I don't have to wire up ground for the jacks every time). It is basically this:
Run Off Grove bread board power module
If you are looking for more control (the kind of stuff a proper bench power supply provides) then you will probably just have to bite the bullet and buy one
- my favorite amplifier: 1986 Gallien-Krueger 400RB
- Completed builds: BYOC 2-knob compressor
Klon Buffer
Devi Ever Ruby, OK, Hyperion
EP-boost->Modded SD1
Meathead
Hunny Bunny
Roger Mayer Voodoo Bass (excellent)
Zendrive
Big Muffs (Russian, P19, Jordan Creator, Jumbo Tonebender)
Lots of other miscellaneous pedals that aren't worth mentionin - Location: MA, US
- Has thanked: 7 times
- Been thanked: 6 times
- Contact:
I've got a professional lab supply that somebody left on the street! I think mine's 30 volts at 5 amps, which is far more than you'll ever need.
