3Leaf Audio - Wonderlove Envelope Filter
Posted: 14 Feb 2013, 23:14
by drbob1
From the name and the controls makes me wonder if it's a subset of the Meatball? Missing the high pass filter and some slight functionality in the other switches. Sounds killer and at $269? Price seems VERY right.
Re: 3Leaf Audio Wonderlove Envelope Filter
Posted: 15 Feb 2013, 09:07
by pedalgrinder
buy one and trace and put it on here. :applause:
Posted: 15 Feb 2013, 15:31
by Nocentelli
Yeah, I'd also put money on it being a Meatball. I assume that the "band" switch is for LP/BP, and not "bandwidth" like the Meatball. I can see why they've
left off the HP mode, as it's a bit of an extreme "niche" sound, but I do find the bandwith switch helps set the envelope triggering, which can be tricky - Maybe they've improved the envelope detection section and made it unneccessary?
Posted: 28 Feb 2013, 09:07
by FunkySpence
The filter section of the Wonderlove is very similar to the Meatball/Mutron. The detector circuit is somewhat unique. It's all surface mount - I'd be seriously impressed if you guys traced it. Here's a gut shot:
Posted: 28 Feb 2013, 10:11
by ~arph
Well now, that looks very good!
Posted: 01 Mar 2013, 02:36
by FunkySpence
Thanks. It's been a while since I designed the PCB, but from looking at it I can tell you that all the stuff near the power jack is related to the relay switching (the big white box, of course, is the relay). One of the quad op amps on the lower edge of the board is the state-variable filter which is controlled by the LED/photocell arrangement on the right. No goop, so anyone who's motivated enough could probably trace it out.
