Vibro Champ Intensity pot
KHELSTROM
Post by KHELSTROM »
I can't find a 25K reverse audio taper pot for the intensity control of a Vibro Champ so would a 25K linear taper pot work fine?
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
You could try RG's tricks.
selectortone
Post by selectortone »
While you're looking for a reverse taper pot you can use a regular audio taper pot and wire it backwards. Of course the pot works in the reverse direction but at least it'll get you working.
kurtlives
Post by kurtlives »
Its a 50K RA pot.
Anyways I just finished a Vibro Champ. I could not find a 50K RA so I just use a 50KA and it worked fine.
