How to Etch Circuit Boards?
Stratman69
Post by Stratman69 »
I've been wanting to build some Vox V846 Wah-Wah clones again.
Unfortunately, my source on eBay hasn't been selling his hand-crafted V846 circuit boards for quite some time.
Basically, to cut down on waiting time and costs, I want to etch my own V846 circuit boards.
I'm totally new to this and I'm not sure exactly where to start.
I see Radioshack sells copper clads and etching solution.
Any help or suggestions on how to etch a circuit board, save on costs, and create good results?
phatt
Been thanked: 338 times
Post by phatt »
For a one off pcb? go buy it as it will turn out much much cheaper and about 30 years less painful. :secret:
Phil.
Motter
Has thanked: 32 times
Been thanked: 121 times
Post by Motter »
Perfboard
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi Stratman,
Do a google search about "toner transfer pcb method", and you'll se how can your board be done simply ironing a xerox copy faced to the copper foil.
oldrenegade
Post by oldrenegade »
Have just recently been experimenting with this. Lots of tutorial u-tube videos available. I found glossy magazine paper the best for transfering your image and a toothbrush helps clean away all the small bits of paper left prior to etching. Found all supplies on ebay. You will need access to a toner printer. Permanent marker pens make good touch up pens.
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
ppluis0 wrote:Hi Stratman,
yep.. also, the forum has a search feature..
viewtopic.php?f=45&t=9530
viewtopic.php?f=45&t=12973#p144209
viewtopic.php?f=6&t=14719&p=167940#p167863
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Nobody reads my tutorial......... :cry:
Image Ken
stevie1556
Post by stevie1556 »
Where abouts are you? If you're in the UK and have the artwork for the circuit board, send me a PM as I've got a full etching set up :)
