2-in-1 w/ buffered bypass
Posted: 25 Feb 2013, 05:48
by mattlee0037
Ok, so for my next build I wanted to do a take a jab at 2 boosts in a single enclosure. I wanted to put the 'simplified Klon' with the red rooster able to switch independently.
Now I've seen diagrams for wiring like this with true bypass, but I'm at a bit of a loss because of the Klon's buffered wiring and such. Now I realize for starters, that I believe a wire should run from input to a middle lug on the switch, but other than that I have no idea how I would go about wiring these effects together in a box. I went through all the active threads, and some are about 2-in-1 enclosures, but have the true bypass switching. Also I'm not sure if the Red Rooster would be wired as true bypass, or if it would matter because the Klon would be buffered? Sorry for the long winded post. I attached the two files for the circuits in question. Any help would be appreciated!
Re: 2-in-1 w/ buffered bypass
Posted: 27 Feb 2013, 14:42
by mattlee0037
Anyone?
Posted: 27 Feb 2013, 14:59
by benobo
Posted: 27 Feb 2013, 22:24
by mattlee0037
So I keep everything the same on the klon and just overlay the extra wirings?
Posted: 18 Jun 2013, 19:26
by Taller76
probably easier to build an NPN RR/RM treble boost since the one you attached is PNP and the Klon is "standard" neg ground.
