Doubt about dpdt switch
joaopereira
Post by joaopereira »
Hello!
i bought a F435A which is a dpdt switch.
i would like to do the millenium circuit because i want the LED to go on when i switch on.
i got this pdf which explains the wiring very well but i have two doubts about it
http://www.generalguitargadgets.com/pdf ... gi_mil.pdf
First: my switch doesn't have any indication in any part so i can't distinguish the lugs. i cant do the wiring without knowing is lug is what. is there any instruction guide ou video that explains how to recognise this lugs?
Second: in the pdf, i think it's an error, one of the lugs of the LED doesn't appear linked. where do you think should be linked?
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
2) LED's leg should be connected with GND, btw, LED's cathode side (the shorter leg) is slightly flattened as you may see on the diagram
1) just follow the instructions - you can't go wrong
Use your multimeter and check the continuity in both positions:
you should have continuity between A-C and B-D - in one position
and C - E and D - F in the other position (see the picture below)
There's a nice video from Mark Hammer - The inner life and rehabilitation of stompswitches
DPDT switch
joaopereira
Thank you very much. This is very helpful!
friedtransistor
my favorite amplifier: Marshal Class v
Completed builds: Mad Professor Deep Blue delay, Mark Hammer's Chaos Fuzz, and an overdrive for my friend at church.
Been thanked: 25 times
Post by friedtransistor »
Also, if this helps, here's the schematic I use:
For all you starwars fans...
Sorry, downsized by request.
Did I mention I love bass?
