OK sorry for the double post hung back for 20min to crank it with no family present.. I had the Hao Rust Driver in the chain to A/B First thoughts (bright only):
1) had a 470pf ceramic in the feedback and it confirms to me my feelings about ceramic in the signal chain.. Less than luster LOL I put a 500pf silver mica in and boy did it pick up. My build was pretty indistinguishable from The hao. You can here slight I mean ultra slight differences between the 2 but I would chalk that up to different op amp chip me 4559.... Hao 4558. I have the same chip with change.
The clippers are different too (calling out for a swap if anyone has 1ss119's I'll trade fro a pair or buy outright.) Hell just this could be the whole enchilada
2) Cap discussion The 680pf in the Hao is a polystyrene which to my ears are really glassy and open but the tolerances and how they hold up long term are suspect. To bad because I think that's the best choice for this build. I will have to get 50pc of 680pf just to cull out 10 that will be the right value LOL. I have gone through to many .01's in my life time that were a good 20% off. I am positive based on my tests that if I took out the 680p it would be more like 500-560p measured. The silver mica's are more focused but not as open. Don't take this to deep from me it is a very very subtle thing. The ceramics are only good to bleed off tone for me I can't use them in signal chain anymore. Which brings up:
3) I have to build a silver mica (have 10p silver mica so 2x parallel) or get a polystyrene 22p, if it exists, for the first stage. The Hao used a ceramic but I would bet $'s for donuts that that will make the pedal more transparent and musical
4) Tonight I will get the switch caps in order. This is about a day away for being buttoned up. I have ripped this vero apart like 10 times LOL I am to lazy to bread bard it so I am building a bread board set up so I don't have to burn my fingers left and right re working my next build LOL. SO... I will re build the vero and take the off board components and put them on board to clean things up a bit...
5) hiss levels are exactly the same from my build to the Hao
