I built a Ge Fuzzface for a friend and he likes it a lot but asked me to make it run with the standard +9V dc supply, if possible.
Of course the circuit is with PNP transistors and positive ground,so I was wondering if there is a standard layout for reversing the polarity from +9V to -9V and add it to the circuit so that it works fine as is.I suppose there should be an op-amp to do such a thing along with some filtering and regulation.
Thank you for your help!
