UICs (Unidentifiable Intergrated Circuits)
friedtransistor
my favorite amplifier: Marshal Class v
Completed builds: Mad Professor Deep Blue delay, Mark Hammer's Chaos Fuzz, and an overdrive for my friend at church.
Been thanked: 25 times
Post by friedtransistor »
Anyone have the slightest clue what these two chips are? I've tried to figure out what they are, but nothing has come up so far...
For all you starwars fans...
Sorry, downsized by request.
Did I mention I love bass?
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi friedtransistor,
The first image you posted belongs to an display driver. This is the link to their datasheet: http://www.datasheetarchive.com/9368PC-datasheet.html
The second chip maybe an LF442 but I'm not completely sure. If it's a dual operational the best test you can do is to plug in a breadboard, mount some diagram that employs a dual op amp (like a Tube Screamer, an OCD, a Marshall Guv'nor or the like) and test if work in that application.
In this case I recommend that you place a resistor of 100 ohms in series with the supply pin of this chip to avoid blow it up and damage your breadboard (yes, I have a couple of breadboards toasted... :lol: )
friedtransistor
Omg, thank you so much, this helps so much... I got these chips at a flea market/garage sale type thing. As to the second chip, I'll test it as an op amp again. I'm not sure if I have before or not... I'll see whether the lf442 is a single or dual.
ppluis0
Post by ppluis0 »
As said previously you can mount in a breadboard one of these 8 pins chips, mount the components for a TS or the like and see what happens.
It's important to put a resistor in series with the supply pin and measure if develops a voltage drop across it. This is to avoid flames and/or fumes during test and this way you can compare the current consumption of a know LF442 against this specimens.
Good luck !!!
friedtransistor
442 chip is a no-go. Either it isn't an opamp, or it's a dead opamp. And I had forgotten to put a resistor on the supply, but the chip remained cold. Oh well, thanks anyway for the info... :hug:
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
Maybe it's a single op-amp
LF442 is dual
NTE 442-22 is single
442-22 NTE Equvilent NTE941M
http://www.weisd.com/test/GenericParts_ ... id1=442-22
http://www.weisd.com/store2/NTE941M.pdf
friedtransistor
wow, you are good. I'll give this a try. Btw, how did you know what numbers to search? I tried all the numbers on that stupid thing and couldn't come up with anything...
karul
Post by karul »
friedtransistor wrote:wow, you are good. I'll give this a try. Btw, how did you know what numbers to search? I tried all the numbers on that stupid thing and couldn't come up with anything...
I wasn't 100% sure that it's an opamp, so I've searched for "ic 442-22", and one of the top links was:
Btw, the logo is "National Semiconductor".
friedtransistor
Thank you! It worked! I made this circuit to test the chip after reading the datasheet:
It sounded great, and when I changed the feedback resistor to a 1m, it sounded like an overdriven amp. I tried an LM741 in the circuit, and it didn't sound as good. I like the 442-22 better than an LM386. Maybe even more than a JRC386. What is the difference between the two? I have an LM386 and JRC386, and the JRC seems to have a better sound and not overheat as much...
karul
Post by karul »
I can't find much more info about 442-22 except that it's a NTE941 equivalent.
http://nte01.nteinc.com/nte%5CNTExRefSe ... enDocument
LM741 and NTE941 are general purpose operational amplifiers, LM386 is audio power amplifier.
NTE941 (442-22) and LM741C are equivalents and there is no difference between the them if you compare the datasheets.
Good for you if you're pleased with the sound of 442-22 - use it.
friedtransistor
Sorry, I meant between the lm386 and jrc386... :blackeye
karul
Post by karul »
Well, LM386 and JRC/NJM386 have same pinout, so they are to some extent interchangeable. Their internal circuitries are not the same.
There are different versions of LM386:
LM386N-1
LM386N-3
LM386N-4
You can use LM386N-1 with 4-12V power supply (absolute maximum ratings 15V)
For LM386N-4 you can use 5-18V supply (absolute maximum ratings 22V)
JRC/NJM386 have operating voltage of 4-12V (absolute maximum ratings 15V)
Both have same voltage gains from 20 to 200, same THD 0.2%.
Also there is a LM /JRC 386B.
LM386B have operating voltage of 5-18V (absolute maximum ratings 22V), THD 0.1%
Datasheets:
http://www.ti.com/lit/ds/symlink/lm386.pdf
http://semicon.njr.co.jp/eng/PDF/NJM386_E.pdf
http://users.ece.utexas.edu/~valvano/Da ... LM386b.pdf
For a tonal differences and preferences you are the judge.
