Wampler - Faux Spring Reverb
will-scarlet
Been thanked: 49 times
Post by will-scarlet »
The sounds of surf rock
Like Dick Dale would always play
Cowabunga, dude
apollomusicservice
Has thanked: 64 times
Been thanked: 819 times
Post by apollomusicservice »
Very nice work. :thumbsup
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
You are on fire dude
Really good work I must say
Hope there's more coming
skywise
Has thanked: 48 times
Been thanked: 22 times
Post by skywise »
You jerk! Now Wampler's going to have to spend more money on lawyers. :horsey:
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
Why are there two identical split-supplies?
Why is a direct-coupled opamp input tied to a second half-supply?
Why is such a high value resistor used?
Why is the unused opamp input tied to ground?
Why not use this unused opamp to stabilize the lossy tone control of the circuit and eliminate the circuit's variable output impedance?
Why are there redundant decoupling capacitors?
WHY WHY WHY WHY WHY?
Is the trace good? I'm not doubting whoever traced it, I'm just confused by these "design decisions."
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
jymaze
Has thanked: 86 times
Been thanked: 171 times
Post by jymaze »
Thanks for that trace, but there has to be some mistakes: The depth pot won't act as supposed, and the tone pot won't work much either.
I am pretty sure IC2B is a summator too. It would make more sense (it would be R9 goes to 6, R19 goes to 6, R15 is in the feedback loop, R10 still goes to 5 and now makes sense at this place).
For the tone I think C10 goes to ground, after the tone pot.
The depth pot somehow should loop around the Belton brick.
I may try to retrace from the pictures. If you have more of them,can you please post? In particular under the pots of course...
Frabbio
Been thanked: 95 times
Post by Frabbio »
Jack Deville wrote:Why are there two identical split-supplies?
I guess the identical split-supplies are used to limit interferences between different sections of the circuit, but apart from this i think there are some errors in the trace.
will-scarlet
I will revisit
Sorry for any errors
Thanks for your patience.
jymaze
Post by jymaze »
Thanks for opening and tracing at first! Some errors are expected in the process, but you will get it right I bet.
Beedoola
Has thanked: 15 times
Been thanked: 32 times
Post by Beedoola »
any corrections on the schematic/verification?
Beedoola
Post by Beedoola »
So I bought a Faux Reverb and I took it apart and as far as I can tell, this schematic is correct.
One thing; the label in the brick has been removed. Any guesses on what is used for this circuit?
I'm going to order the parts soon and breadboard it to confirm.
Thanks.
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
Don't know about original brick...
but
I built it with BTDR2 (long tail) and it works great.
It has almost same pinout too
Beedoola
Post by Beedoola »
You mean you built the Faux according to this schem? Did you happen to make a layout for it?; vero, perf, PCB?
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
will-scarlet wrote:The sounds of surf rock
Cowabunga, dude
Please don't build them that way. That output is wack.
edit: a closer look... from the depth pot forward is messed. It's not too far off from the mixing section of the datasheet. Building the circuit as shown here won't sound anything like the FSR.
Mbas974
Post by Mbas974 »
I built my reverb using all the goods I found on web.
Looking around all BTDR built are close but not equlals.
80% is Faux design and the rest is from other (like feedback from GGG).
Brian, you're right the schematic on beginning of topics is NOT the Faux. In your design why do not use half TL for feedback ( it makes the reverbs like shimmering ) ?
Anyhow, I called it the "CRASTER REVERB", feel free to built it, and mod it as per your personal taste. ( This is NOT the Wampler clone !! )
Ciao !!
alexradium
Been thanked: 68 times
Post by alexradium »
Cowabunga, dude
i don't get why people pretend to be smarter than they really are,publishing schematics obviously wrong from a technical point of view,its happened many times here and in the end the original builder gets it in the a$$ because hundreds of people build the pedal the wrong way and come out on boards saying that sucks big time. :hmmm:
indyguitarist
Cowabunga, dude
Maybe I misunderstand, but I'm not trying pretend to be smarter or anything, I just don't want people to say the pedal sucks after trying a DIY version. I also know that half of the fun is putting the puzzle pieces together of a design, so I offered some insight into what was wrong.
alexradium
I wasn't referring to you,Brian,you are SMART enough to make your businesses in a good way,for sure.
Beedoola
Post by Beedoola »
I think I fixed the output...
indyguitarist
Beedoola wrote:I think I fixed the output...
Look at the application circuit on page 3 of this pdf:
https://www.smallbearelec.com/Projects/BTDR-1H.pdf
hint: Notice the last opamp stage. That can be turned into a low pass filter very easily.
You are close, but still not there. :)
