Wampler - Faux Spring Reverb
Beedoola
Has thanked: 15 times
Been thanked: 32 times
Post by Beedoola »
indyguitarist wrote:
Beedoola wrote:I think I fixed the output...
Look at the application circuit on page 3 of this pdf:
https://www.smallbearelec.com/Projects/BTDR-1H.pdf
hint: Notice the last opamp stage. That can be turned into a low pass filter very easily.
You are close, but still not there. :)
I appreciate the hint but I'm very noobish and I can't figure anything out from the Belton PDF. Perhaps someone more savvy than myself can figure it out.
biliousfrog
Completed builds: Zen Drive, Fuzz Factory, Really Cheap Compressor, D*A*M 66, Klon Buffer, CryBaby mods, Boss TR2 mods, Various loops and switchers, DOD250, Fulltone Bass Drive, MXR Bluebox mods
Been thanked: 9 times
Post by biliousfrog »
It has been said numerous times before but: Brian, you really are a gent. Many lesser designers/builders would have been upset that their pedals were being de-constructed, yet you're offering gentle encouragement like a primary school teacher. :thumbsup
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
Thank you, I appreciate that :)
Beedoola
Post by Beedoola »
I breadboarded the circuit and it sounds great but I still can't figure what Brian from Wampler is talking about.
indyguitarist
Beedoola wrote:I breadboarded the circuit and it sounds great but I still can't figure what Brian from Wampler is talking about.
I'm sure it'll work as the schematic posted has it, it's just not the faux spring reverb circuit from us. You need a variable low pass filter on there that's inverting.
mmolteratx
Has thanked: 93 times
Been thanked: 618 times
Post by mmolteratx »
Try the datasheet mixer with the 50k pot in series with the 22n cap in the NFB. I think that's what Brian's saying. See the Deuce Coupe tone control for what I'm talking about.
EDIT: Wait, I forgot I drew this up months ago. Here's the schem.
EDIT2: Holy crap, it's been almost a year. My bad. :lol:
Beedoola
Post by Beedoola »
mmolteratx wrote:Try the datasheet mixer with the 50k pot in series with the 22n cap in the NFB. I think that's what Brian's saying. See the Deuce Coupe tone control for what I'm talking about.
rad! it works!!
Beedoola
Post by Beedoola »
The decay on mine is a little shorter, and I'm guessing the brick in the Faux isn't a Short.
Anyone know? The label on the brick is removed...
Blend
my favorite amplifier: Marshall jcm 800, Soldano, Brunetti
Has thanked: 45 times
Been thanked: 53 times
Post by Blend »
you can find the specifications in this site Wampler, "2.8s max reverb time."
R4 in the picture seems to 33k .....?
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
R4 33K could makes sense, it is a high pass filter with 22n cap.
Working point down to 219hz instead 2.19Khz
Thanks, Blend !
Beedoola
Post by Beedoola »
Blend wrote:you can find the specifications in this site Wampler, "2.8s max reverb time."
Yes, thanks! Good eye. I looked over a pic I took of the PCb and it is a 33k.
And thanks for pointing out the 2.8 seconds on the Wampler site. Problem solved!
Beedoola
Post by Beedoola »
here are some build shots
fuzzfiend
Post by fuzzfiend »
Looking at the schematic, what is the benefit of using a J201 on the output of the brick rather than the unused op amp? :hmmm:
Q: How many bluegrass musicians does it take to change a light bulb?
A: Three. One to change the bulb and two to complain that it's electric.
gibsonvedran
Post by gibsonvedran »
I tried the last schematic and I don't think is correct, the depht control does not work as it should, It increase the volume of 'the effect at max setting...it's normal? You have had success with that scheme ?
fretzburner
Post by fretzburner »
gibsonvedran
which is the schematic that you used?
Beedoola
Post by Beedoola »
fretzburner wrote:[ Image ]
upload img
[ Image ]
adult image upload
Damn, dude. Crazy nice perf work!! :applause:
gibsonvedran wrote:which is the schematic that you used?
I'm willing to bet he used the schematic a few posts above provided by MMolterax. Thats what I used as well.
gibsonvedran
But with that schematic the depth raise the volume of the verb more the length of decay... The decay is the same in all depth settings... Your depth control is ok beedoola?
gibsonvedran
mmolterax schematic is equal to your schematic Beedoola...
And brian said that your schematic was not correct... "You are close, but still not there."
fretzburner
Yes the schematic above is what i'm using (R4 -33k) and sounds fine to me.
