teleK: Nasty clipping goes for any opamp clipping, not something I will try to create.
MoonWatcher: I have done this - still, as someone pointed out above, it is not enough since other valuable parameters come into play.
Sorry for the confusion, but all this is meant for a solid state amp I built, not a pedal. And I use quite a bit of gain, if we are to compare the cases. And since I heard something that my ears did not like when using a lot of volume capable of driving the amp, I posted that question. I will lower my gains as you folks mention, I will not depend on a scope. But just out of
curiosity, I wanted to get some more info. No ruling out of low methods.
Because, look at the above posts - a member said something about 100mV-200mV. On the net, you find posts about 10mV. Go check a Fender schematic, giving a test voltage of 5mV. Seems like there are quite big differencies between random opinions. Not that this is weird, anyway, I just want to gather information so as to gain experience.
After all, I don't find it nice working on numerous circuits with an input that sometimes is not well-defined. (please note the word in bold
