Greg Fryer Brian May Treble Booster Stripboard
insonicbloom
Been thanked: 19 times
Post by insonicbloom »
another link to a (as always) verified stripboard of what has to be my favorite treble booster to date
although it is very Brian May it has alot of potential to sit in a lot of mixes and band situations - I'm sure someone has youtubed the original - this sounds exactly the same as the original
http://www.paulinthelab.com/2013/03/gre ... oster.html
Intripped
Has thanked: 941 times
Been thanked: 303 times
Post by Intripped »
this is not clear to me: did you trace the circuit by yourself (having the real pedal in front of you), or you are getting all the info from this other thread?
if you have the real pedal, maybe you can help in confirming the values of the 2 10pf caps (supposed values in the other thread)
thanks!
insonicbloom
yes - they weren't very clear I desoldered them and measured. I'm a bit annoyed - I did a search for the schematic for this so I didn't have to bother tracing it. found sod all - then the moment I post this it pulls it up as a "similar post to this"
so I'm sorry if it looks like I'm stealing his work and saying it's my own but I didn't, I traced it myself/risked wrecking it by desoldering parts from it and I didn't need to.
Intripped
Post by Intripped »
well, at least now we all are very sure about this treble booster
...no more secrets around, after this double tracing! 8)
insonicbloom
Intripped wrote:well, at least now we all are very sure about this treble booster
definitely - I am trying to get enough money to get all 3 boosters, though I suspect that they will be exactly the same apart from a few cap/resistor values
mojah63
Has thanked: 39 times
Been thanked: 24 times
Post by mojah63 »
