This is an old thread but I have to set the record straight. Valiant effort by
camljenkins94 but the original schematic posted in
https://gitlab.com/jofirel/uterror-amp/ ... master.zip is >90% correct. The board has 2 layers and many of the traces are covered by the components making it impossible to trace from the photos alone.
I was able to trace the board from micro terror SN 10131-1112 by using a combination of visual and multimeter probing so I am quite certain of the results.
Kudos to José Relvão who did the original tracing. The following are where his and my tracings differ:
1. R2 wired to Vbias and not GndRef
2. Gain circuit C7 connected to VR1A wiper not to R8-C6 node.
3. R17 is 220k instead of 100k
4. R20 is 47k instead of 150k
5. R22 is 220k instead of 1M
6. Several discrepancies in power section. Most notably, Tube heater powered via 12V regulator. See attached schematics for more details
7. STA540 pin 6 connected to C32 47u cap. This is missing in the original.
Of special note is the tone control circuit which is 100% correct including the dubious short across R24. I suspect this was added by the original designer as a means of detecting if the design was copied since it makes no sense. Of course, it could always be an oversight by Orange
. I would just leave out R24.
I have modified the original schematic and attached it below.
