Mountainking Electronics - Megalith  [traced]
Eyeofowl
Been thanked: 26 times
Post by Eyeofowl »
I have been a long time lurker here and wanted to contribute. This is the first pedal I have traced and drawn a schematic for. It would be nice to get a second set of eyes, but I only have a crappy phone camera. I can post my perf trace if need be.
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Looks like something is burned........
ringworm
Has thanked: 25 times
Been thanked: 88 times
Post by ringworm »
I had been wondering about this pedal. Some guts have turned up online. Is your copy a clone or re-housed pedal?
Some random images,... none of which are mine...
There's a trim pot on the board of that last one. It's for active pick-ups, not sure where it goes.
Eyeofowl
Post by Eyeofowl »
My buddy got this pedal from Wino(Saint Vitus, Shrinebuilder, etc.). The bottom plate is numbered 1 and the signature matches the one in your pic. It may have gone through some revisions by now...
ringworm
Post by ringworm »
Wow! That's some Pedigree!
The layout still looks the same but i couldn't say if values have changed from the pics.
Eyeofowl
Post by Eyeofowl »
After trying to put this together on vero, I realized there were multiple resistor errors and a wrong cap. At least I learned something... Always double check component values and use a multimeter if in doubt. I haven't done a comparison with the original, but everything is working and it sounds good. Here is the updated Schematic:
onebuzz
Has thanked: 64 times
Post by onebuzz »
I was puzzled why mine did not work. I'm a touch colorblind so those metal film resistors are a bugger to read. Thanks for the revised schematic.
destro
my favorite amplifier: Peavey Classic Series
Been thanked: 36 times
Post by destro »
100ka on the output, I am assuming?
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Your polarity protection diode is burned out, replace it and check for shorts.
ringworm
Post by ringworm »
destro wrote:100ka on the output, I am assuming?
The schematic in the original post had the output pot listed as 100kB.
atreidesheir
Has thanked: 441 times
Been thanked: 43 times
Post by atreidesheir »
onebuzz
Post by onebuzz »
Just posting a circuit shot of my workalike device. Turned out pretty good.
Eyeofowl
Post by Eyeofowl »
Ice-9 wrote:Your polarity protection diode is burned out, replace it and check for shorts.
It's in parallel. I am under the assumption that it is kind of useless to replace? I guess I could put one in series for my buddy, but I am kind of lazy.
onebuzz wrote:Just posting a circuit shot of my workalike device. Turned out pretty good.
Awesome! did you add the notch shift rotary? I was going to just wire up a Dpdt(on-off-on) with 10n, 10n, and 22n to get 10n, 20n, and 32n. Close enough I think.
onebuzz
Post by onebuzz »
Just added a single pole on-on switch with .01uf and .033uf.
agoldoor
Has thanked: 39 times
Been thanked: 21 times
Post by agoldoor »
How can no one have posted a layout for this yet, or confirmed the schem yet? =)
agoldoor
Post by agoldoor »
Bump for a vero? =)
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
There you go
agoldoor
Post by agoldoor »
G'damn you rule IV!
agoldoor
Post by agoldoor »
Wow, and already verified by onthetundra! Everyone here works quickly! =)
agoldoor
Post by agoldoor »
Alright, I finally completed my build of this one... and I have to say, HOLY GOD!
This is EASILY the loudest pedal I've ever built or played. A lot of other pedals I've built or played that border on that edge of being the "MOST" of something end up also being on the verge of farting out, or completely falling apart (transistors completely gating with certain knob settings, high volume breaking out into squealing/oscillation, etc.)... but this certainly doesn't do that. I was unable to play around with this guy on anything more than 1.5 on my amp's volume knob. It's THAT GOD DAMNED LOUD.
Glad this one's been traced though finally, bravo to all involved.
:applause: :applause: :applause:
