Celestion V30 Sim Vero
jaylow
Post by jaylow »
Hello! I was wondering if someone could have a look and double check this stripboard layout I came up with for the Celestion V30 Sim. The only difference is that I don't have the 1M resistor at the input and no output cap. Are those necessary? This will be wired directly from a buffered splitter and sent to another jfet buffer hooked up to an XLR output to form a line out that can be hooked up directly to a PA.
Also, I'm using a TLE2074 instead of a TL074 because I have a bunch of TLE2074 laying around. TI says they're direct upgrades, so why not?
The schematic is taken from here: http://milas.spb.ru/~kmg/files/projects ... 30mSch.pdf
