CMATMods - Deluxe Signa Compressor
- IvIark
Looks like a Dyna Comp to me. You'd need to go over the values to see exactly what they modded, but the BYOC 5 knob compressor is a Dyna with tone and attack controls plus a blend and so should be pretty close.
- pedalgrinder
anyone who likes decent compressor's you see a ca3080 and
- IvIark
The BYOC has a blend control as well and so you would expect more components, but if we get some decent gut shots then a trace of this would be pretty quick to appear. It will be very close to a Dyna/Ross with some of the extra controls used in the BYOC I suspect. Maybe some different values here and there but you can see clearly what it is based around.Roast7 wrote:But this uses very less components IvIark
You have the VERO from BYOC?
Think you we can catch the layout, of this signa?
- mmolteratx
- Degoop Doctor
$100 says a passive tone control and the standard attack mod.
tone isn't quite passive since the signal cut from the +ve input is boosted in the output. tone gets thinner as roll the knob up.
