Psionic Audio Fuzzy Logic
- my favorite amplifier: Orange
- Completed builds: Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Hornby Skewes Treble Booster
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver - Has thanked: 7 times
- Been thanked: 13 times
Nice reverse buffer. Works well if you love the buffers and fuzzes too. Seems a simple circuit. I'm checking the values...
- DSCF1500.jpg (32.34 KiB) Viewed 1708 times
- DSCF1499.jpg (22.96 KiB) Viewed 1708 times
- DSCF1498.jpg (34.24 KiB) Viewed 1708 times
- DSCF1495.jpg (40.4 KiB) Viewed 1708 times
- DSCF1494.jpg (36.71 KiB) Viewed 1708 times
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
- Pot it's 10K lineal.
- Panasonics are 22nf.
- Resistors on the left: red, brown, black, orange and brown.
- Resistors on the right: green, white, white, orange, brown.
- Letters on the side os the transformer: 0912S
- Blue capacitor: 3312
- Bernardduur
Cool! No power supply needed???
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
No, it's a passive effect. Should be placed just before the fuzze(s) in a effect loop. Works well with treble boosters too...Bernardduur wrote:Cool! No power supply needed???
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
Any possibility of getting a schematic drawn-up?, wouldn't mind building one......
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
Can anyone help me do this scheme or layout? It's the first time I do it
I thing it's very similar to the Guitar Pickup Simulation of AMZ (Jack Orman) http://www.muzique.com/lab/pickups.htm
I will take best pictures of the PCB...
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
The back of the PCB.
Switch is 2 positions DPDT
- FWEFWEF.jpg (52.77 KiB) Viewed 1603 times
- lohstah
pictures of the component side are not good enough to discern the connections...either post better ones or look where the components connect and tell us.
start of the circuit must be completely similar to the muzique circuit, up to the sc-hb switch. check from then on to see where the rest of the components fit in. 330p cap must be at the end of the circuit to gnd, res pot is the tone pot, one of the 22n caps is prolly in the tone pot circuit to ground.
cheers,
lohstah
cheers,
lohstah
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
More pics...
- DSCF1510.jpg (52.24 KiB) Viewed 1360 times
- DSCF1506.jpg (52.3 KiB) Viewed 1360 times
- andrej
- my favorite amplifier: Vox AC30
- Completed builds: Zvex Woolly Mammoth
Boss DS-2 mod
Vox AC4
Crowther Hotcake (and own variations)
TS-808
Big Muff Russian
Big Muff IC
Superfuzz
Superfuzz
Big Muff
Mixer/Blend
various other stuff - Location: montenegro
- Has thanked: 6 times
- Been thanked: 51 times
- Contact:
i bet on:
http://www.muzique.com/lab/pickups.htm + a buffer before it.
what you don't know is that it's not needed: fuzzes and treble boosters like high impedance (reactive or resistive, whatever) on the input, which is why they don't like buffers. you just need to add a 50-100K resistor (or a 100K pot/trimmer) between the output of your buffer of choice and the input of the fuzz pedal.
tried it and it works like a charm.
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
Passive buffer?
- andrej
Boss DS-2 mod
Vox AC4
TS-808
Big Muff Russian
Big Muff IC
Superfuzz
Superfuzz
Big Muff
Mixer/Blend
- Contact:
oh wow! no buffer at all, didn't look
