DIY Programmable True Bypass Looper PCB Kit
- gtrplaya101
Pre-Order Now! Kit will come with PCB and all required digital chips (2- Master, Slave)
Expected first shipment of: 6/1/13
EffectBlade is the very first and only DIY Programmable True Bypass Looper.
Features:
•6 mono loops
•2 stereo loops (end)
•2 amp controls
•8 presets per bank, 3 banks
•Ground Lift on each bank.
•3 operation modes (Override, Combination, Looper)
•Completely scalable! No need to build the whole thing out if you arent going to use them (I will provide guides on how to do this!)
•100% analog signal path
Loops 1 thru 6 on the EffectBlade are simple mono loops, meaning each loop features a send and return. These loops are great with overdrives, boosters, phasers and more. Each mono loop features its own ground lift if you find yourself experiencing any kind of pop while switching.
Loops 7 & 8 of the EffectBlade are wired to be stereo. Each loop features a left and right send/receive. Stereo loops work great with stereo pedals such as modulation effects and delays. If you do not wish to use the stereo loops simply plug your mono pedal into the left send/return jacks and use as normal. Like the mono loops the stereo loops also feature a ground lift option.
For more information and to order:
http://www.efxdigitaldesign.com/pcb-sho ... blade-pcb/
Features:
•6 mono loops
•2 amp controls
Do you have a list of components required on top of the kit to build this?
Are you able to disclose what microcontroller you are using?
Will purchasers be able to get hold of the source files to customise the programming?
Thanks,
Ian
Thanks,
Ian
- Mbas974
Ciao Franco, welcome on FSB .
Frank is the one of the greatest and trusted source for DIY guys here in Italy.
Unfortunately his site is in Italian... but I'm sure he will working on it
Grat project ! ( as always )
- chicago_mike
Where in Italy...the woman of my dreams lives in Rome!
Skyline FX 2013
chicago_mike wrote:Where in Italy...the woman of my dreams lives in Rome!
