Help! a newb here,I need to know if I fried this or..
Behold! the unicorn!
my favorite amplifier: Fender twin reverb
Completed builds: TBA-about to start a BYOC lazy sprocket
Post by Behold! the unicorn! »
Do I have the input and output hooked up right? I drew a rough schematic since I lack the ability to read them at this time.I am trying to learn if someone could help me with this I would greatly appreciate it.The pedal is a DOD fx-90 if anyone can post up an example that would be great.. And how could I tell if it is just fried?
Lucifer
my favorite amplifier: Vyse BBQ Blue
Has thanked: 89 times
Been thanked: 72 times
Post by Lucifer »
Without a diagram of what you've done, how can we tell if you've got things the wrong way round ? And how can we tell if you've fried anything ?
Below is the circuit - available from the Free Information Society website - but if you can't read it, what are you going to do with it ?
It's certainly not the simplest of circuits for a newbie to start on. I'd suggest you try something a bit easier until you get the hang of things.
Good luck :thumbsup
Output jack
Output jack
Output jack
input jack
input jack
Lucifer
Post by Lucifer »
I'm afraid the photos don't help - apart from showing a green earth on your input jack, and a blue or purple one on your output jack - why the different colours ?
I always standardise my main colours - RED for +ve, BLACK for 0v, YELLOW for Input, BLUE for output - it makes fault finding so much easier.
Is that a LED connected to your input jack ? If so, why ?
The bottom of the big circuit diagram is copied below - it shows the FX-90 board and connections. From what I can see from your photos, you've connected up differently.
Change your wiring to get it to the same state as the diagram, then test your pedal again.
DOD FX-90 Board.gif (35.22 KiB) Viewed 1465 times
Yeah I will switch to those primary color's again "thats a good idea" thanks for the help I will try and figure it out.
Has thanked: 218 times
Been thanked: 857 times
I do have the impression the posted photo's show a later revision of that the schem posted... That might cause some :scratch:
Fixed btw.. all the mod's are working and it is really great.
Lucifer
Post by Lucifer »
Well done :thumbsup
Your next one should be easier.
