Teese RMC4 Wah  [schematic]
jb1911
Been thanked: 7 times
Post by jb1911 »
Anyone add an LED to their Pic Wah? How did you do it?
jb1911
Post by jb1911 »
Pic wah pic
jb1911
Post by jb1911 »
With the effect switched on, none of the lugs on the switch show 9v.
Relays are beyond my knowledge.
juanro
Has thanked: 51 times
Been thanked: 117 times
Post by juanro »
That switch is unfamiliar to me, but check if there is continuity between the two unused legs (on the upper left in your picture) and so you can use it to switch the LED.
Juanro
Has thanked: 218 times
Been thanked: 857 times
Or has the Teese RMC4 wah never been traced? As far as Google goes (you wanna buy? buy? buy?) there seems nothing to be found!
RMC4 schematic
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
could be a firefox problem but link doesn't download the schem? :whappen: ..just a blank page
Sorry. Works here in IE and Firefox. "Save as" doesn't work either?
rocklander
nope.. but could certainly be the way my firefox is set up.. it just opens a blank page...
can confirm it's sweet as in chrome though :thumbsup
Mrdorbe
Post by Mrdorbe »
Question, when you write the value 472E or 10E on a resistor is it Ohm?
and when you write 10/25 or 100/25 on caps is it 10/100uF 25V ??
thanks
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Mrdorbe wrote:Question, when you write the value 472E or 10E on a resistor is it Ohm?
It is, yes.
Mrdorbe wrote:when you write 10/25 or 100/25 on caps is it 10/100uF 25V ??
And yes, it's capacitance / rating. :wink:
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Post by lolbou »
sinner wrote:Thats 3 digit codes http://www.hobby-hour.com/electronics/3 ... istors.php
When it's stamped on SMD resistors, it's the code indeed. But on the schematic above, 472E definitely means 472 ohms.
You meay see 100R too, R standing for ohms too.
edit : just remember this:
analogguru wrote:"E" is used in german countries to describe "Ohm". It is derived from the german word "Einheiten" which means: units.
"E" is used instead of the Omega-symbol to avoid confusion with 0 - which may occur especially on bad copies... e.g. "390" is this now 39 Ohm or 390 ? 39E instead gives a clear answer....
I never seen 472r value resistors bro. Dirk, clear it up please
Ok. I just looked on the schematic and it cant be 4k7 on emitter resistor. So I'm wrong
lolbou
Post by lolbou »
sinner wrote:I never seen 472r value resistors bro. Dirk, clear it up please
Indeed... :scratch:
dai h.
Has thanked: 46 times
Been thanked: 12 times
Post by dai h. »
possibly a typo (supposed to be 471? = 470ohms)?
Intripped
Has thanked: 941 times
Been thanked: 303 times
Post by Intripped »
is C25 really supposed to be 47nF?
it's a bright cap on the volume trimmer/pot, isn't it?
i've a 47nF in my wha pedal at the moment and i can't adjust the volume properly
maybe 4,7nF or 470pF would be the correct value?
thanks (and happy new year! :) )
