Can I replace SMD by normal resistor?
Dulouz
my favorite amplifier: My Egnater Tweaker 15
Completed builds: Wampler mods on a 90's Danelectro Fab Tone
Post by Dulouz »
Hey Guys!
I was replacing the footswitches on my DL4. While I was disconnecting one of the mountain switches my pliers slipped and I nicked the R29 resistor. I got everything wired up, but now that switch is the only one that doesn't work. Could the damage to the resistor be the problem? I've quadruple checked all of the solder joints and everything looks good.
Here's a photo:
yes :wink:
Dulouz
Post by Dulouz »
Ha! Thanks!
Can you replace SMD components with through hole?
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Yes, you'll just need to solder the leads to the pads. It'll be a bit fiddly but do-able.
Duckman
Has thanked: 320 times
Post by Duckman »
looks like 1/8w resistor got almost the same size... almost :hmmm:
Güero 2.0
Been thanked: 24 times
Post by Güero 2.0 »
Here, code 1001
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Just stick on a 1k through hole resistor, use a soldering iron to try and catch both sides of the smd resistor at the same time and it should just stick to the tip of the iron when you push the iron to remove the resistor.
Dulouz
Post by Dulouz »
Thanks for the help everyone!
I had an extra 1K resistor handy and I soldered it to the pads with no problem.
Now all the switches work perfectly!
