Wampler Velvet Fuzz  [traced]
michaelballard
Been thanked: 12 times
Post by michaelballard »
Sure, just let me know what you need. I'll leave it apart until we have a good trace.
mganzer
Has thanked: 29 times
Been thanked: 21 times
Post by mganzer »
Guys, i think is time to move to dissected boutique stompboxes section.
michaelballard, please open the thread, repost the photos and take the credit. This section do not have many people looking for. In dissected section this will have more visibility imho.
Intripped
Has thanked: 700 times
Been thanked: 220 times
Post by Intripped »
^ maybe a moderator will kindly move this 3D, no need to repost everything i think (?)
update: the RE is finished, i made some guesses but i'm 98% sure it's correct. i'll post the results soon
Intripped
Post by Intripped »
here we go:
the traces in orange are my guess
Nocentelli
Has thanked: 863 times
Been thanked: 791 times
Post by Nocentelli »
So, just cap values and JFET drain voltages needed? Excellent work, many thanks.
I'm interested in why opto-couplers were used - Presumably a DPDT switch wired to route the input either through the 386 or the 5089 would also work here?
michaelballard
Nice work! I'll get the cap values and drain voltages sometime in the next day or two - been a busy work week.
I'm curious about the optoFETs as well - maybe a fancy way to prevent popping when switching between the two?
Intripped
Post by Intripped »
yes, caps values needed
and JFET drain voltages should be 4,5V as written on the PCB, but michaelballard might easily measure them.
about optocouplers, i think a 3PDT would do the trick: when one input is selected the other one is also grounded (through a further H11F3) - to prevent oscillations (?)
Probably Brian W. adopted this method in order to make the switching silent - otherwise i don't understand the additional costs/complication
michaelballard, i was writing while you posted your answer - anyway i see we agree :D
Eisy
Been thanked: 73 times
Post by Eisy »
So the JFET section is just a standard Plexi-Drive...
charlietheunicorn
Post by charlietheunicorn »
i think OK1 has to be mirrored, isnt the Collector Emitter path placed in the wrong direction?
michaelballard
Cap values -
C1 220uF
C2 100n
C3 4n7
C4 1n
C5 220n
C6 100n
C7 1uF
C8 470n
C9 100pF (I think - says WIMA 100/100 2.5%)
C10 220n
C11 10n
C12 100n
C13 2n2
C14 100pF (I think - says WIMA 100/100 2.5%)
C15 22n
C16 47uF
C17 100pF (I think - says WIMA 100/100 2.5%)
C18 1uF
C19 2n2
C20 47uF
michaelballard
Eisy wrote:So the JFET section is just a standard Plexi-Drive...
Looking at the PlexiDrive schematic, the cascaded JFET stages are almost identical - except the "gain" pot is now "fuzz" and the "tone" pot is now "bright".
Time to get out the breadboard out and get ready to match some JFET's :)
MoonWatcher
Has thanked: 41 times
Been thanked: 43 times
Post by MoonWatcher »
michaelballard wrote:Nice work! I'll get the cap values and drain voltages sometime in the next day or two - been a busy work week.
Since there is no form of gain adjustment until after Q2, it probably makes more sense to look at both of them as boosters set to max.
You basically have a fuzz that is not adjustable as one would normally be - it's like controlling the fuzz at your amp.
That is the tricky part with these fuzz-meets-amp distortion designs. Unless you want 20 knobs and switches, there has to be a decision made as to where the gain is going to be adjustable.
I guess the only other choice would be to handle it like the Skreddy Screwdriver, giving two different points of gain adjusting. But the Screwdriver just has the mosfet input booster. This one has the choice of bipolar or power amp chip.
I think a pot for blending the 386 or bipolar might be ultimately more interesting, but would add some complexity and issues. It might also have a spectrum of mostly less than dramatic settings for the average user.
The best part with this pedal is the simplicity - both the bipolar and the power amp are really quite basic booster stages. Brilliant. Someone said the amp/FET part is the Plexi Drive pedal? As in without alterations? Double brilliant, even if it required just modest alterations.
I'm surprised no one has thought of doing what looks somewhat obvious to me - make a simple bipolar and 386 boost pedal to cascade into the front of a plexi-type or other FET-type pedal of your choice. You could knock that out on vero in an hour or less. You wouldn't have to bother sorting FET's (or sourcing them) for a pedal you may already have. And if you only use tight or loose, the complexity drops by half. :thumbsup
Lucifer
my favorite amplifier: Vyse BBQ Blue
Has thanked: 84 times
Been thanked: 72 times
Post by Lucifer »
Hi MB,
Thanks for all your data and pics.
Do you have a value for C20 ?
Intripped - thanks for your rapid trace of the circuit. Take a bow.
michaelballard
Sorry, just added C20 to the post above. It's 47uF.
If we're good with the trace, I'm gonna put this thing back together and grab drain voltages - although I'm sure they're 4.5v since that "amp" stage is a PlexiDrive.
Nocentelli
Thanks again to eveyone involved in tracing this out, fired up on the breadboard first time. Works great with a 3PDT switching the inputs and grounding the opposite one, maybe the optoFETs impart even more sonic mojo but it sounds really good anyway.
I'd be straight onto making a vero right now if my ancient version of diylc hadn't gone wonky a few weeks ago. Maybe I'll get it sorted by the weekend.
mganzer
Post by mganzer »
getting a final working schematic (with a solution h11f3less) i do a 1590b board layout.
okgb
Has thanked: 192 times
Been thanked: 30 times
Post by okgb »
Nice work guys ! makes me think I'll try a plexi drive and put that boost in front of it to have both !
Nocentelli
OK, here's a first go at a vero layout. I've been over it a fair few times, but there may well still be errors. I'll be building it tonight, so I should be able to verify it (or not...) by tomorrow.
I've replaced the optoFET fuzz mode switching with a 3PDT that grounds the input to the unused fuzz section, and I've added a DPDT switch to bypass the fuzz altogether for a pretty much stock plexidrive (as suggested by okgb above - It works well on the breadboard).
I also omitted the power protection, cos i don't worry about that stuff. It strikes me that a 4P3T rotary switch might be the most elegant way to have the choice of plexidrive/fat fuzz/tight fuzz, all on one control. The pedal would then have what looked like four knobs and no switches (much nicer IMO).
crw414tele
Post by crw414tele »
Just checking if I understand correctly ,on comparing the plexi drive schematic with the one Intreppid posted the fuzz pot is just the gain pot renamed ? Does this then mean that with the fuzz part switched off it will function as a normal plexi drive. I've already built the plexi and love it , but it would be great to be able to have both pedals in one , maybe even have the fuzz on a foot switch.
Nocentelli
Yep, the input stages (the 386/2N5089) just slam the input of the plexi section to get the fuzz sound. You could just trim off everything below 'row i' and leave off everything to the right of the cut at i8 to build the input/fuzz stages.
