Ibanez - TS-9-HW Handwired Tube Screamer
Posted: 20 Jul 2013, 09:10
Hi guys, this is my first topic here and i need to ask you something. I've already searched everywhere but i didn't find anything.
I want to made a ts9 hand wired, like the ts808hw that ibanez did a while ago. I'm using this pcb layout and these wiring layout 1 & 2
The difference between ts9 and ts808 (i think) it's in R15 and R16, the ts9 uses 470R and 100k resistor instead of 100R and 10k, but i'm not sure. Can anyone tell me if i'm wrong?
The second question is about wiring: in the wiring layouts there are 4 cables that start from pcb: input, output, 9v and ground. In the pcb layout there is a VR (i don't know what is this) and 4 9v cables. Power cables can be easily soldered on the dc jack pin, but i have no idea what vr exit is and where it should be placed. LED is a problem too,
the 2nd layout says to solder it to the 9v cable, but the pcb layout says to solder the led with R23. I guess it's ok because R23 it's connected to 9v by 2 jumpers, but i'm not totally sure.
This is my second pedal and i don't speak english very well, i'm sorry if you can't understand something
