http://blueguitar.org/new/text/fulltone_thread.pdf
Daniel R. Haney wrote 3/25/1998 at Ampage forum: wrote:I may be the last to have figured this out, but...
I got to look inside a Way Huge Green Rhino pedal. It is a tube screamer design with the JFET switching removed and true bypass in its place. Parts quality is top notch, audiophile grade in many places. Has the same old 1N4148 diodes for clipping.
The emitter follower sections were TO-18 form 2N2484's (hfe=250, NPN, small signal). The op amp markings had been sanded off. (Markings?? We don't need no steenking markings!)
The Green Rhino sounds like a low-noise TS-808 with rough edges removed. At $150, it cost as much as a vintage TS-9, half of what a TS-808 does, but sounds better than both of them and is guaranteed for life. Sheesh.
I can do this, I just know I can.
