Long time lurker and my experience is pretty small (built one amp and no pedals).
Short version:
I would like to rehouse/mod my pedal with a footswitch to switch between 2 gain and volume pots on my pedal. I have sketched the problem here. I would also like/need an indicator LED to light up when the 2nd set of pots was engaged.
When I think about it, I run out of connections pretty rapidly as I would do it the longwinded way of taking each of the connections from the board to the middle of the switch and then branch off to each of the new pots.
Can any of you work out how this could be done? There seem to be a few commercial pedals that do this.
Long version:
My pedal has 250k gain pot and in the first 10% of the range it sounds very fat and bluesy, very 'low-gain'. At the high end the pedal is a full on distortion, like a wall of marshalls.
a) I'd like more control over the gain by putting say, a 50k pot in the gain position
b) I'd like to footswitch between 2 settings, low gain (50k pot) and high gain (250k pot), but also at different pot settings - I think that I need to have a second vol pot since when I switch to a second higher gain pot the volume will go up too much.
c) I'd ideally like an led if but if not possible then I could live without it (probably).
Thanks for any help you can offer.
