I've token some photos of Noll Mixpot 1, and tryed to redraw the shematic. As all can be seen without opening anything, it's not a problem to show this on the forum, is it ? I'll delete files if it is.
It's a active blend pot with two separate input stage with +18db trim gains and a output buffer.
There's not many active blend without eq. The only other one i know is emg abc, but seems only to be two buffers.
I'm really newby in electronic. There's maybe some mistake. It's seems me a interesting schematic for study.
It's only 0,6mA. No idea of the op amps, but they must be very low current, a bit lower than a tl061.
Blend pot is 50k.
_wouldn't it be better if there were decoupling capacitor for op amp supplies in parrallel of 1M resistors ?
_isn't it a problem all those electrolytic caps on signal path ?
_any mod suggested ?
Thanks !!
