I`d very much appreciate a hand with a non working Orange Squeezer.
Mine is the early 80s Maxon built model reissue. Well made, fairly true to the original I think, and neat inside with the Tubescreamer chip, but bought as junk for $20.
But...
Bypass works fine.
NO signal with switch in on position
Checked battery and battery snap.
Checked using it at amp end instead of at guitar end (Although I do not know which way the wires should be connected for either
Poked about for any odd noises/loose wires, nothing...
Here`s some gutshots: I have limited knowledge, but it seems a relatively simple circuit?
Any help much appreciated, thanks!
(NB. Hole in the front is a feature of the Maxon made models allowing access to the internal trim)
