PT2399 delay formula
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
Hi, is there a formula I can use for Delay calculation with PT2399 : Delay-time Vs resistance-value ?
I have a table from datasheet showing some delay time and resistance values but I can't get the formula...
I'd like to build the echo-base having a multi-switch option for specific delay time.
THANKS
induction
Has thanked: 61 times
Been thanked: 116 times
Post by induction »
Regression of the table gives a nice linear formula:
delay = 1.14657e-5*R + 0.02974,
with delay in seconds, R in ohms.
This formula reproduces the table*, but I make no guarantees that the table is accurate or consistent between devices.
*The maximum error between the formula and the table is 4.2 ms, the average error is 1 ms.
gena_p1
Has thanked: 23 times
Been thanked: 11 times
Post by gena_p1 »
accurate method to get delay time is only to measure frequency at pin5 of PT2399, than regulate resistor value. Like PLL.
With analog delays is the same thing.
